fiyat : 350tl
görsel olarak sıdır gibidir
İletişim : 05335124447
POWER SUPPLY Power supply voltage: . . . . . . . . . . . . 11 ÷ 15 VDC Idling current: . . . . . . . . . . . . . . . . . . . . . . . . . 0.6 A Idling current when off: . . . . . . . . . . . . . . 0.002 mA Musical max consumption: . . . . . . . . . . . . . . . 15 A AMPLIFIER STAGE Distortion –THD (1 kHz; 4 Ohms): . . . . . . . . 0.05 % Bandwidth (-3 dB): . . . . . . . . . . . . . . 4 Hz ÷ 50 kHz S/N Ratio (A weighed @ 1 V): . . . . . . . . . . . . 95 dB Damping factor (1 kHz, 4 Ohms): . . . . . . . . . . . 150 Pre In input sensitivity: . . . . . . . . . . . . . . . 0.2 ÷ 5V Speakers In input sensitivity: . . . . . . . . . . 0.4 ÷ 10V Pre In input impedance: . . . . . . . . . . . . . 15 kOhms Speakers In input impedance:. . . . . . . . . 100 Ohms LOAD IMPEDANCE: - 2 Ch. . . . . . . . . . . . . . . . . . . . . . . . . . 4 - 2 Ohms - 1 Ch. . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Ohms NOMINAL OUTPUT POWER (RMS) NP @ 12VDC; THD 0.3% 4 Ohms: . . . . . . 45W x 2 OUTPUT POWER (RMS) @ 13.8 VDC; THD 1%: - 2 ch (4 Ohms) . . . . . . . . . . . . . . . . . . . . 65W x 2 - 2 ch (2 Ohms) . . . . . . . . . . . . . . . . . . . . . 85W x 2 - 1 ch (4 Ohms) . . . . . . . . . . . . . . . . . . . . 170W x 1 FILTERS/INPUTS Inputs: . . . . . . . . . . . . . . . . . . Pre In / Speakers In Filters: . . . . . . 12dB/Oct., bypass / hi-pass / lo-pass . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . (50÷220) Hz OTHER FUNCTIONS Remote IN: . . . . . . . . . . . . . . . 7 ÷ 15 VDC – 1 mA Connections for VSR kit for SUB remote volume:. . . . . . . . . . . . . optional kit Fuse: . . . . . . . . . . . . . . . . . . . . . . . . . . blade, 20 A Protection: . . . . . . . . . . . . . . . . temperature >85°C, DC voltage, overload Green-red LED indicators: . . . . . . . . . . . . on-safety MAX SIZE (D x H x L): . . . . .178 x 49.5 x 210 mm WEIGHT: . . . . . . . . . . . . . . . . . . . . . . . . . . .1.5 kg
