Subigarage
19 Kas 2019
Japonya'dan aldığım Pioneer Carrozeria Hoparlör satılıktır.
Carrozeria TS-V07A Komponent takım ( pasif crossoverlarıyla beraber) : 10.000 TL
■ Speaker configuration: Woofer / 17cm high acoustic fiber cone (honeycomb type), tweeter / 2.5cm super wide range tweeter (dual arc ring type)
■ Instantaneous maximum input: 150W
■ Rated input: 50W
■ Playback frequency band: 28 ~ 48,000Hz
■ Output sound pressure level: 90dB
■ Impedance: 4Ω
■ Network: <Woofer low pass filter> -12dB / oct
<Tweeter high pass filter> -18dB / oct
■ Mass (1 piece): <Woofer part> 0.56kg
<Tweeter Part> 0.16kg
<Network part> 0.68kg
■ External dimensions: <Woofer part> 156 (W) x 156 (H) x 64 (D) mm
<Tweeter part> φ55.0 x 60.7 (Diameter x Depth) mm
<Network Part> 181.5 (W) x 42.6 (H) x 106.1 (D) mm
■ Mounting dimensions: <Woofer part> φ137 x 58 (opening diameter x depth) mm
297.8 KB
Görüntüleme: 49
246.6 KB
Görüntüleme: 46
117.2 KB
Görüntüleme: 46
282.4 KB
Görüntüleme: 48
294.6 KB
Görüntüleme: 50
226 KB
Görüntüleme: 51
301.9 KB
Görüntüleme: 49
304.1 KB
Görüntüleme: 47
269.9 KB
Görüntüleme: 43
281.3 KB
Görüntüleme: 51
