cenkbasar
19 Ocak 2018
Merhabalar,
2-3 ay önce Berk Hifi'den sıfır olarak almış olduğum Helix G-FOUR amfimi satıyorum.
Ürün full kutuludur. Bass Kontrolü vardır hiç montaj edilmemiştir.
Özellikleri ;
Output power RMS / max. - @ 4 Ohms4 x 80 / 160 Watts- @ 2 Ohms4 x 120 / 240 Watts- @ 1 Ohm- - bridged @ 4 Ohms2 x 240 / 480 Watts- bridged @ 2 Ohms-
Amplifier technology Class AB
Inputs4 x RCA / Cinch
4 x Highlevel speaker input
1 x Remote In
1 x Remote control input
Input sensitivityRCA / Cinch 1 - 6 Volts
Highlevel 2.5 - 14 Volts
Input impedance RCA / Cinch30 kOhmsInput impedance highlevel12 OhmsOutputs4 x Speaker output
2 x RCA / CinchOutput voltage RCA / Cinch1 - 6 Volts RMSSignal converter for digital input- Frequency response10 Hz - 40,000 HzBass boost0 - 12 dB / 45 HzHighpass15 Hz - 4,000 Hz adjustableLowpass40 Hz - 4,000 Hz adjustableBandpass15 Hz - 4,000 Hz adjustableSubsonic- Phase- Slope high- / lowpassButterworth 12 dB/Oct.Slope subsonic / lowpass- Signal-to-noise ratio digital input- Signal-to-noise ratio analog input108 dB (A-weighted)Distortion (THD)0.02 %Damping factor200Operating voltage9.6 - 16 Volts (max. 5 sec. down to 6 Volts)Idle current1000 mAFuse2 x 30 A Maxi-fuse (APX)Additional featuresActive, adjustable crossover, bass boost, input mode switch, highlevel input with automatic turn on function and Advanced Diagnostics Error Protection (ADEP), Start-Stop capability, remote control for channels C & DDimensions (H x W x D)57 x 334 x 241 mm /
2.24 x 13.15 x 9.50”
Fiyat : 1500 TL 1350 TL
Cenk - 5059000045
