fiyat: 600 tl iletişim: 05335124447 kozmatik olarak ufak cizikleri var tamir olarakta kondansatör değişmiş sanırım tam net bilmiyorum isteyene üst kapağını açıp ayrıntılı foto atabilirim ilk sahibiyim şuan çalışır durumda.
Output Power Rating
Power
Stereo Output 4 ohm @ 14.4V (0.05%)
4 x 100W
Stereo Output 2 ohm @ 14.4V (0.05%)
4 x 150W
Bridged Output 4 ohm @ 14.4V (0.05%)
2 x 300W
Channel separation (Full Rated Power)
> 50dB
THD Distortion with 22k Filter
0.10%
Frequency Response (-3dB)
10 - 25KHz
S/N Ratio (A-Weighted)
> 95dB
Input Gain Control
Low Level Input
150mV — 4V
High Level Input
450mV — 12V
Input Impedance
20kΩ
Features
Battery Voltage Range for Operating
10.5V — 16V
LED Indicator
Red/Green
Protection (Short, Thermal, Overcurrent)
Yes
Crossover
HP/FULL/LP
Variable Hi-Low Pass
40Hz — 400Hz
Crossover Slope
12dB/Octave
Bass EQ at FULL/LP at 45Hz
12dB
Dimensions mm / in.
Length
445mm / 17.5 in.
Width
273mm / 10.75 in.
Height
57mm / 2.25 in.
Output Power Rating
Power
4 x 100W
4 x 150W
2 x 300W
> 50dB
0.10%
10 - 25KHz
> 95dB
Input Gain Control
Low Level Input
150mV — 4V
High Level Input
450mV — 12V
Input Impedance
20kΩ
Features
10.5V — 16V
LED Indicator
Red/Green
Yes
Crossover
HP/FULL/LP
40Hz — 400Hz
Crossover Slope
12dB/Octave
12dB
Dimensions mm / in.
Length
445mm / 17.5 in.
Width
273mm / 10.75 in.
Height
57mm / 2.25 in.
