Emanetci_61
19 Ocak 2018
Ürün kendi aracımda 2 ay takılı kalmıştır sorunsuzdur ciziksizdir yanındaki griler hiç takılmamıştır baş kontrol kullanılmamıştır zorlanmamıştır
kredi kartına %8 komisyon ile 3-6 taksit yapılır
  • Total Max Power: 1800W
RMS Power Ratings
  • Per Channel into 4ohms, 14.4V (≤1%THD+N): 600W
  • Per Channel into 2ohms, 14.4V (≤1%THD+N): 900W
Sound Tuning
  • Subsonic Filter (Subwoofer): 8-40 Hz (-24dB/oct)
  • Crossover Frequency (LPF): 50-400 Hz (-24dB/oct)
  • Equalizer (Bass EQ): 0-12dB (Fc 50Hz, Q Factor 1.3)
General
  • Power Requirements: 14.4 V.DC (9 - 16 V allowable)
  • Input Sensitivity (RCA Input): Hi: 0.4 - 10 V Lo: 0.1 - 4.0 V
  • High Level Input with automatic power on
  • Cable size: Power Cable 4AWG (20mm2), SPK Cable 8AWG (8mm2)
  • Frequency Response (+0, -3dB: 1W into 4 ohms): 8-400Hz
  • THD+N (10W into 4 ohms): <0.02%
  • THD+N (600W into 4 ohms): <0.07%
  • Damping Factor: >1500
  • Signal to Noise (Rated Power into 4 ohms): >107dB
  • Weight: 3.2 kg
Dimensions
  • Heat Sink (WxHxD) mm: 297 x 51 x 192
