SATILDI
DLS MS6A Component >> 460 TL
DLS yi anlatmama gerek yok gerçek anlamda müzik dinlemek isteyenler için ÜRÜNÜN SADECE TWEETER I 132 EURO'dur o yüzden saçma sapan tekliflerde bulunmayın. Bu paraya bu kalitede compenent bedava
sahibinden de ilan no : 393445156 ilanımda olan tüm malzemeleri kafama yatan ürünlerle takas yapabilirim
Midbass Özellikleri
6-1/2" Reference MS Series Component System
Power Handling:
Peak: 320 watts per set / 160 watts each side
RMS: 200 watts per set / 100 watts each side
Metal cone woofer
Rubber surround
1.1" Silk dome tweeter
Crossovers with selectable tweeter level in three steps
Filter box with 6/12 dB slope (LP/HP)
4 ohms impedance
3.94" Wide magnet
Top-mount depth: 2.64"
Authorized Internet Dealer
1-year Manufacturer's warranty
Tweeter Özelliklleri ;
Power handling capacity: 50 W RMS
Max power handling capacity: 80 W
Frequency range: 1,500 - 20,000 Hz
Fs - Resonant frequency: 1200 Hz
Rec. crossover point: 4 - 5 kHz
Sensitivity: 93 dB (1W/1m)
Magnet size: 28 mm (1.1")
Outer diameter: 60 mm (2.36")
Mounting depth: 18 mm ( 0.71")
Mounting hole: 48 mm (1.89")
Midbass Özellikleri
Power Handling:
Metal cone woofer
Rubber surround
4 ohms impedance
3.94" Wide magnet
