Sevgili Arkadaşlar,
Sıfır aldığım ve kısa süre (6 ay) kullandığım Helix P TWO amfi satılıktır. Sıfır diye satılabilir. İğne ucu çizik dahi yok.
Fiyat 500 EUR.
Saygılar
Fiyat 500 EUR.
Saygılar
Technical data
Output power RMS ≤ 1% THD+N | |
- @ 4 Ohms | 2 x 280 Watts |
- @ 2 Ohms | 2 x 490 Watts |
- @ 1 Ohm | - |
- bridged @ 4 Ohms | - |
- bridged @ 2 Ohms | - |
Max. output power per channel* | Up to 600 Watts RMS @ 2 Ohms |
Amplifier technology | Ultra HD Class D |
Inputs | 2 x RCA / Cinch 2 x Highlevel speaker input 1 x Optical SPDIF (28 - 96 kHz) 1 x Remote In 1 x Remote control input |
Input sensitivity | RCA / Cinch 2 - 8 Volts Highlevel 5 - 20 Volts |
Input impedance RCA / Cinch | 10 kOhms |
Input impedance highlevel | 13 Ohms |
Outputs | 2 x Speaker output |
Output voltage RCA / Cinch | - |
Signal converter for digital input | BurrBrown 32 Bit DA converter |
Frequency response | 10 Hz - 40,000 Hz |
Bass boost | 0 - 9 dB / 40 Hz - 120 Hz |
Highpass | 15 Hz - 4,000 Hz regelbar |
Lowpass | 15 Hz - 4,000 Hz regelbar |
Bandpass | 15 Hz - 4,000 Hz regelbar |
Subsonic | - |
Phase | - |
Slope high- / lowpass | Butterworth 12 dB/Oct. |
Slope subsonic / lowpass | - |
Signal-to-noise ratio digital input | 105 dB (A-weighted) |
Signal-to-noise ratio analog input | 105 dB (A-weighted) |
Distortion (THD) | < 0.005 % |
Damping factor | > 200 |
Operating voltage | 10.5 - 16 Volts (max. 5 sec. down to 6 Volts) |
Idle current | 2400 mA |
Fuse | 3 x 30 A LP-Mini-fuse (APS) |
Additional features | Active, adjustable crossover, bass boost, input mode switch, highlevel input with Advanced Diagnostics Error Protection (ADEP), Auto Remote switch, SPDIF Direct In switch, cable remote control for volume adjustment |
Dimensions (H x W x D) | 50 x 260 x 190 mm / 1.97 x 10.24 x 7.48” |
Ekli dosyalar
Son düzenleme:
