Akın
8 Şub 2017
hertz hdp4d kullandigim bi anfi hakkinda bilgi vermek istedim
4x150 4ohmda
4x250 2ohm da
2x500 4ohm da
cihaz güclü bir anfidir.
midrage icin kullanilir genelde
d clasdir fazla elektirik cekmez.
  • OUTPUT POWER (RMS) @ 14.4 VDC, THD 1%:
  • 4 Ch 150 W x 4 (4Ω)
  • 4 Ch 250 W x 4 (2Ω)
  • 3 Ch 150 W x 2 (4Ω) + 500 W x 1 (4Ω)
  • 3 Ch 250 W x 2 (2Ω) + 500 W x 1 (4Ω)
  • 2 Ch 500 W x 2 (4Ω))
  • Power supply voltage: 11÷15 VDC
  • Idling current: 1,5 A
  • Idling current when off: 0.04 mA
  • Consumption @ 2Ω, 14.4 VDC
  • (Max Musical Power): 50 A
  • Amplifier stage
  • Distorsion - THD (100 Hz @ 4Ω): 0.08 %
  • Bandwidth (-3 dB): 5 ÷ 55k Hz
  • S/N Ratio (A weighted @ 1 V): 100 dB
  • Damping factor (100 Hz @ 4Ω): 50
  • Pre-In sensitivity: 0.3 ÷ 5 V RMS
  • Pre-In impedance: 15 kΩ
  • Speaker-In sensitivity: 1.4 ÷ 24 V RMS
  • Speaker-In impedance: 470 Ω
  • Load impedance:
  • 4 Ch 2Ω
  • 3 Ch 2 x 2Ω ÷ 1 x 4Ω
  • 2 Ch 4Ω
  • Thermally optimized double extruded heatsink, ergonomic and aluminium die-cast
  • end caps;
  • 4 LEDs monitor the status of the amplifier and communicate with the user;
  • Special balanced input circuitry to reject electromagnetic disturbances present on the Pre-amplified or Speaker level inputs;
  • HDP Input featuring either Speaker In (OEM radio) and RCA In (Aftermarket radio) inputs;
  • ART™, Automatic Remote Turn-On/Off function, automatically turns on and off the amplifier when the OEM radio turns on and off (available on Speaker In only);
  • Full range Pre-out, also available when using Speaker Level In inputs;
  • 12 dB/Oct. continuously adjustable (50 to 5k Hz and 80 to 3.3k Hz) active crossover with Lo-Pass/Hi-Pass or Full Range settings;
  • A/B Input switch eliminates the need for RCA Y-Adapters;
  • Power supply stage featuring multiple winding transformer, Low-ESR 105°C capacitors, D-Class 2 Ω stable output stage based on solid T220-5pin power Mosfets.
  • Click
