Sevgili Arkadaşlar,
JL Audio Slash 250/1 crome amfim satılıktır, Ürün Türkiye de tektir.
Forum üyelerine özel fiyat 500-TL
İletişim : 05443598313
mono subwoofer amplifier
250 watts RMS x 1 at 1.5 to 4 ohms
Regulated, Intelligent Power Supply system
differential-balanced inputs
variable low-pass filter (40-200 Hz, 12 or 24 dB/octave)
variable bass boost (0-15 dB at 48 Hz)
switchable infrasonic filter (-24 dB/octave at 30 Hz)
optional wired remote bass boost
Class-D amplifier design
MOSFET power and output stages
speaker- and preamp-level inputs (speaker-level input requires an optional adapter)
4-gauge power and ground leads and a 30-amp fuse recommended — wiring and hardware not included with amplifier
no onboard fuses — when installing multiple amps in a system, an additional 30-amp in-line fuse between the distribution block and the amplifier is recommended
10-1/4"W x 2-5/16"H x 10-3/16"D
