Elimde 2 adet zapco amfi vardır sıfır kutusunda kullanılmamıştır.
Trde sıfırını bulmak zordur bu kalitede artık amfileri değerlendirmek lazım. Tabiki kullanıcı olarak
Ürünün bir tanesi DC. 750.2
Features:
Features:
- Stereo, 4 ohms: 2x175 Watts
- Stereo, 2 ohms: 2x375 Watts
- Bridged, 4 ohms: 1x750 Watts
- T.H.D. + Noise: <0.022%
- S/N Ratio: >95dB
- Slew Rate: >40V/uS
- Damping Factor: >1000@4 ohms
- Dimensions: 23"L x 7.5"W x 2"H
- SymbiLink Balanced Inputs
- RCA Unbalanced Inputs
- 2 ohm stereo stable
- 18 dB variable bass boost control
- Dual variable electronic crossovers with x10 switch
- Bridgeable
- Three channel capable
- High Current Bi-Polar output devices
- Optically isolated MOSFET power supply
- Aux output (Highpass/Lowpass or Fullrange)
- Switch for use as stereo, single L ch. or R ch. bridge
- L+R Sum Mono for use as a bass amp
- Cooling fan allow any mounting position
- Four layer PC board with heavy 2 oz copper
- Surface mount technology w/1% resistors,
- precision caps, and massive ground planes
REF750 - Zapco Reference 2 Ch. 750 Watt Amplif - Fiyat 750.2. 2200 tl
- 350.2 1900 tl
- İletişim ö.m veya iletişim hüseyin 5358110624
